"Login with USER first" error message
pfan
I get the error message: "Connection failed. Login with USER first" whenever I try to connect to WinSCP. We recently had a new security software installed (zscaler) and I was given FTP exception access but it still doesn't work. Does anyone know how to fix this?
  • logs.txt (2.68 KB, Private file)
Re: "Login with USER first" error message
It looks like the server may not support TLS/SSL encryption.
> 2023-11-14 15:37:29.758 AUTH TLS
< 2023-11-14 15:37:29.778 503 Login with USER first
> 2023-11-14 15:37:29.778 AUTH SSL
< 2023-11-14 15:37:29.797 503 Login with USER first
Did you try to connect with "No encryption"?
Well, then it look like your FTP server is completely broken.
Or can you connect to it anyhow? Using any other FTP client?
