How to Configure MimeTypes using the WinSCP.ini file
                I am using WinSCP v6.1.2, and I am trying to set the
Thanks!
        MimeTypes using the WinSCP.ini file.  Everything I have tried is not working.  What is the correct syntax and format to use in the .ini file to configure the MimeTypes and File Associations?
Thanks!
