Invalid access to memory after timeout when grabbing a file
trevor.woolley@...
Version 6.2 beta (Build 14434 2023-10-05) portable
Reproducible by attempting to do an SFTP file transfer from a router via a socks proxy, file transfer also fails on versions 5.21.7 and 6.1.2, but does work with FileZilla. Cannot directly connect to this router.
Happenings: Successfully logs into router, retrieves directory list, when file is dragged across for copying from the device, it times out.
For the attached log file the following command was issued from a "cmd" prompt -->
winscp.exe /log=log.txt
Description: Log file
Re: Invalid access to memory after timeout when grabbing a file
Thanks for your report. Though I cannot reproduce the problem.
trevorw
Sydney / Australia
Thank you Martin,
I have registered now, please note I must use a portable version, and if it was not a link it was likely stopped before I can see it.
trevorw
Sydney / Australia
Thank you Martin,
I've attached a zip of the output, but I did not see the Invalid Access to memory, yet the SFTP still timed out.
  • WinSCP59C4trace.zip (885.54 KB, Private file)
Description: Adding the zipped log/debug outputs
Thanks. Do you have an access to that server without proxy from some other location? Or do you have another SFTP server (something more standard – OpenSSH) that you can access via the SOCKS proxy? I'm trying to narrow down the problem. Both SOCKS and Cisco are rare on their own, let only their combination.
WinSCP does not receive a response to FSTAT request from the server. FileZilla does not use FSTAT for a regular transfer. So that might be, why the download works in FileZilla.
One think you can try: The FSTAT would be used by FileZilla, when resuming the transfer. So can you abort download of a file in FileZilla and retry it (selecting "Resume")? (and post FileZilla log file for that)
trevorw
Sydney / Australia
Filezilla Log
Thank you again Martin,
Unfortunately, filezilla, whilst aborted, and resumed twice during the transfer showed no issues. I also tried shutting the application down mid transfer, and it was able to resume as well upon restarting and re-connecting.
I've attached the log.
  • filezilla.log (6.79 KB, Private file)
Description: filezilla.log
Re: Filezilla Log
Sorry, I was wrong. FileZilla uses FSTAT when resuming upload, not download. Can you try that?
What about my other questions?
trevorw
Sydney / Australia
Re: Filezilla Log
Thanks Martin,
When the upload is broken, FileZilla starts again and does not resume.
As for your other questions, sorry I missed adding the response in.
  • No the only access to that server is via a proxy
  • Access to a Linux (Centos) server, does work through the same proxy.
trevorw
Sydney / Australia
Re: Filezilla Log
Sorry, I have attached the one I just did for you, aborted once during the process.
Description: filezilla log with aborted upload
Re: Filezilla Log
FileZilla logging is not very detailed, but I believe this indicates the same problem WinSCP is facing with your server:
2023-12-15 06:14:14 24584 2 Command: reput "C:\TEMP\45021___.KNL" "45021___.KNL"
2023-12-15 06:14:34 24584 2 Error: Connection timed out after 20 seconds of inactivity
2023-12-15 06:14:34 24584 2 Error: File transfer failed
So I'm pretty sure it's a server-side bug.
trevorw
Sydney / Australia
Thanks again Martin,
That the server is doing something wrong, doesn't overly surprise me, that being said, FileZilla was still able to send the file, after the above-mentioned disconnection, without user intervention, beyond requesting if to override the partially sent file or not.
If you plan to leave it at this point, I understand, it means for these devices I need to use an alternate application.
As I wrote, FileZilla (actually pysftp, internally used by FileZilla) happens to use another API to query size of the file. So it avoids the bug.
Though even its download code contains this comment:
     * FIXME: we can use FXP_FSTAT here to get the file size, and
     * thus put up a progress bar.
So it might happen that future versions stop working with your server too.
