Background connections when happening quickly causes error
elephantspirit
When many background connections are started, errors come up. Usually invalid key, this is all using SFTP.
Can be reproduced by
  1. Have background transfer set above 4, the higher the more likely to trigger the bug. I used 9
  2. Making a folder with 10~ files
  3. Edit them all in a text editor
  4. Save all in editor causing WinSCP to upload them all
  5. Error pop up, clicking OK on all error pop ups gets all uploaded eventually.
I previously made a bug report about this. It's been a bug since after 5.17.
. 2023-12-15 14:29:45.277 [Background 1] Remote version: SSH-2.0-OpenSSH_8.9p1 Ubuntu-3ubuntu0.4
. 2023-12-15 14:29:45.277 [Background 1] Using SSH protocol version 2
. 2023-12-15 14:29:45.278 [Background 1] Have a known host key of type ssh-ed25519
. 2023-12-15 14:29:45.286 [Background 2] Remote version: SSH-2.0-OpenSSH_8.9p1 Ubuntu-3ubuntu0.4
. 2023-12-15 14:29:45.286 [Background 2] Using SSH protocol version 2
. 2023-12-15 14:29:45.287 [Background 3] Remote version: SSH-2.0-OpenSSH_8.9p1 Ubuntu-3ubuntu0.4
. 2023-12-15 14:29:45.287 [Background 3] Using SSH protocol version 2
. 2023-12-15 14:29:45.287 [Background 2] Have a known host key of type ssh-ed25519
. 2023-12-15 14:29:45.288 [Background 3] Have a known host key of type ssh-ed25519
. 2023-12-15 14:29:45.293 [Background 4] Remote version: SSH-2.0-OpenSSH_8.9p1 Ubuntu-3ubuntu0.4
. 2023-12-15 14:29:45.293 [Background 4] Using SSH protocol version 2
. 2023-12-15 14:29:45.293 [Background 4] Have a known host key of type ssh-ed25519
. 2023-12-15 14:29:45.302 [Background 1] Doing NTRU Prime / Curve25519 hybrid key exchange, using hash SHA-512 (unaccelerated)
. 2023-12-15 14:29:45.313 [Background 2] Doing NTRU Prime / Curve25519 hybrid key exchange, using hash SHA-512 (unaccelerated)
. 2023-12-15 14:29:45.321 [Background 3] Doing NTRU Prime / Curve25519 hybrid key exchange, using hash SHA-512 (unaccelerated)
. 2023-12-15 14:29:45.322 [Background 4] Doing NTRU Prime / Curve25519 hybrid key exchange, using hash SHA-512 (unaccelerated)
. 2023-12-15 14:29:45.465 [Background 1] Received invalid elliptic curve point in ECDH reply
. 2023-12-15 14:29:45.465 [Background 1] Attempt to close connection due to fatal exception:
* 2023-12-15 14:29:45.465 [Background 1] Received invalid elliptic curve point in ECDH reply
. 2023-12-15 14:29:45.465 [Background 1] Closing connection.
. 2023-12-15 14:29:45.465 [Background 1] Asking user:
. 2023-12-15 14:29:45.465 [Background 1] Received invalid elliptic curve point in ECDH reply ()
. 2023-12-15 14:29:45.519 [Background 3] Signature from server's host key is invalid
. 2023-12-15 14:29:45.519 [Background 3] Attempt to close connection due to fatal exception:
* 2023-12-15 14:29:45.519 [Background 3] Signature from server's host key is invalid
. 2023-12-15 14:29:45.519 [Background 3] Closing connection.
. 2023-12-15 14:29:45.519 [Background 3] Asking user:
. 2023-12-15 14:29:45.519 [Background 3] Signature from server's host key is invalid ()
. 2023-12-15 14:29:45.529 [Background 2] Signature from server's host key is invalid
. 2023-12-15 14:29:45.529 [Background 2] Attempt to close connection due to fatal exception:
* 2023-12-15 14:29:45.529 [Background 2] Signature from server's host key is invalid
. 2023-12-15 14:29:45.529 [Background 2] Closing connection.
. 2023-12-15 14:29:45.529 [Background 2] Asking user:
. 2023-12-15 14:29:45.529 [Background 2] Signature from server's host key is invalid ()
. 2023-12-15 14:29:45.560 [Background 4] Signature from server's host key is invalid
. 2023-12-15 14:29:45.560 [Background 4] Attempt to close connection due to fatal exception:
* 2023-12-15 14:29:45.560 [Background 4] Signature from server's host key is invalid
. 2023-12-15 14:29:45.561 [Background 4] Closing connection.
. 2023-12-15 14:29:45.561 [Background 4] Asking user:
. 2023-12-15 14:29:45.561 [Background 4] Signature from server's host key is invalid ()
. 2023-12-15 14:29:48.960 [Background 1] Answer: OK
Re: Background connections when happening quickly causes error
I see that you have indeed reported this already – and I've responded, but you never came back to me...
Anyway, can you please try to find out what exact version (including beta versions) did introduce the problem?
You can download all past versions of WinSCP from:
https://sourceforge.net/projects/winscp/files/WinSCP/
IWouldLikeToBeCalledKurt
Austria
I've the same issue.
Seems to be related to the server response. Can't verify but I think it happens when the server doesn't allow any new connections.
I get this "handshake" error messages when I'm connected to one server with multiple WinSCP instances and all of them use multiple connections in the background.
The messages vary sometimes
Registered server host key is invalid
(if I remember correctly)
Would be great if this error could be catched and forking new background connections could be stopped for this upload or session.
jeffshead
US
@martin: Still happening. I'm using WinSCP-6.5.1-Automation. Server is AlmaLinux 8.10.
I get the following errors when I have multiple files open in EditPad Pro, edit them all and select 'Save all':
This issue does NOT occur every time I have a bunch of files open in EditPad Pro and use the 'Save all' button. It can work fine for hours but when it does happen, it keeps happening every time I attempt to save the files. When this occurs, I have to close all of the files and WinSCP so I loose all of my edits, pray I remember what I modified and start over.
