Synchronize Command only pushes 1 files instead of all
Faizan
I have a below batch script file code which should sync all files to remote from local, however when I run this it only pushes 1 file instead of all files in the folder. All files are CSV file
open CC_BH__LIVECONNECTION
synchronize remote -filemask="*.*" "C:\Users\Admin\NetSuite SFTP\Production\Inbox" "/Inbox"
Re: Synchronize Command only pushes 1 files instead of all
From your description, I guess you might be having this problem:
Upload of file .. was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn off setting permissions or preserving timestamp. Alternatively you can turn on ‘Ignore permission errors’ option.
