Zero byte files downloaded
I am facing an issue where WinSCP downloads same file correct (200B) to
dir_1 and some times downloads zero byte file to dir_2. Some time in dir_2 download is correct and in dir1 file is zero byte.
set timestamp=%DATE:/=-%_%TIME::=-% set timestamp=%timestamp: =% "C:\Program Files (x86)\WinSCP\WinSCP.com" ^ /log="C:\Users\some_dir\%timestamp%.log" /ini=nul ^ /command ^ "open ftp://user:password@some.host.com/" ^ "get -transfer=automatic *.txt<1N>1 c:\some_dir_1\" ^ "get -delete -transfer=automatic *.txt<1N>1 c:\some_dir_2\" ^ "exit" set WINSCP_RESULT=%ERRORLEVEL% if %WINSCP_RESULT% equ 0 ( echo Success ) else ( echo Error ) exit /b %WINSCP_RESULT%
