Script SFTP
MortyDeadMan
Script SFTP
I made a WinSCP script for SFTP. The script sends the files fine, but it freezes after that. It does not execute the rest of the script.
Would you have an idea?
Here is the script:
# Local directory path
LocalDirectory = "D:\RepSource\1\"
# Archive directory path
$Archivesdirectory = "D:\RepSource\Archives"
& "C:\Program Files (x86)\WinSCP.com" `
  /log="C:\Program Files (x86)\WinSCP\WinSCP.log" /ini=null `
  /command `
    "open sftp://serveursftp@sftpcom:22/ -hostkey=`"`"hostkey`"`"" `
    "cd / `
    "put $localdirectory* /" ` # Use the full path of the local directory
    "exit" # Add the exit command
$winscpResult = $LastExitCode
if ($winscpResult -eq 0)
  Write-Host "Success"
  # Move files to archive directory after successful transfer
  Move-Item -Path "$repertoireLocal*.xml" -Destination $repertoireArchives -Force
else
  Write-Host "Error"
exit $winscpResult
