WinSCP stops after 20 Files
ReinerMader
Germany
I'm still new to WinSCP. I currently have a problem that I hope someone can help me with.
The following. I receive around 60 files every day that I want to automatically download at a certain time. After downloading, I delete it.
I created a script that I run using a batch file using the Windows Task Scheduler.
This works quite well so far. However, I have the problem that the download hangs after 20 files. The window just stays stuck. I then have to close the window again and run the script again. Then the next 20 files go and the same thing with the hanging happens again.
I have the following script for this
open ftpes://ftpxxx:password@server/
get -delete "*.csv" "C:\EGIS\Daten\*.csv"
As I said, 20 files are downloaded and then the system hangs without a message. Only canceling the task can end it.
Does anyone have any idea what that might be?
Thank you very much in advance
Reiner
Oh yes, it runs under Windows Server 2019 Standard and WinSCP 6.3
Re: WinSCP stops after 20 Files
ReinerMader
Germany
LOG
Hi Martin, thank you very much for the quick answer. You will find the log files in the appendix.
I started the script three times in a row because only 20 files are being transferred and then the download stops. Today it didn't get stuck, but closed the window cleanly again.
I hope you can do something with the logs.
Thank you very much in advance for your help
  • log.zip (17.85 KB, Private file)
ChristianAnco
Same issue
Since this weekend we have exactly the same issue that it just stalls after about 20 files.
Hope there is a solution for this asap, otherwise i'm forced to find another piece of software to handle this on our side. :-/
