Write Host on Removal of Files during Synchronize with RemoveFiles enabled – PowerShell
johnhamborg
Earth
I am largely following the template provided here
https://winscp.net/eng/docs/library_session_synchronizedirectories#example
I have configured the Removal of Files during Synchronize with removeFiles enabled and I need to write out the status of those operations along with the other sync operations.
In the example, all errors and status are sent through the FilesTransferred function, how do I include the removed files as well?
I tried to add this $e.Removal case, but it does not seem to work.
if ($e.Touch -ne $Null)
    if ($e.Touch.Error -eq $Null)
        Write-Host "Timestamp of $($e.Touch.FileName) set to $($e.Touch.LastWriteTime)"
    else
        Write-Host "Setting timestamp of $($e.Touch.FileName) failed: $($e.Touch.Error)"
if ($e.Removal -ne $Null)
    if ($e.Removal.Error -eq $Null)
        Write-Host "Deleted $($e.Removal.FileName) "
    else
        Write-Host "Could not Delete $($e.Removal.FileName): $($e.Removal.Error)"
else
    # This should never happen during "local to remote" synchronization
    Write-Host "Timestamp of $($e.Destination) kept with its default (current time)"
Re: Write Host on Removal of Files during Synchronize with RemoveFiles enabled - PowerShell
There's no event for file removals.
But all synchronization operations on remote files are recorded in SynchronizationResult returned by Session.SynchronizeDirectories method.
https://winscp.net/eng/docs/library_synchronizationresult
Particularly, see the Removals property:
https://winscp.net/eng/docs/library_synchronizationresult#removals
johnhamborg
Earth
Solved
Thanks for the pointer.
I ended up implementing it like this
$synchronizationResult =
    $session.SynchronizeDirectories(
        [WinSCP.SynchronizationMode]::Remote, $localPath, $remotePath,
        $True, $False, [WinSCP.SynchronizationCriteria]::Time,
        $transferOptionsSync)
# Removals
$Removals = $synchronizationResult.Removals
ForEach ($file in $Removals) {
    Write-Host "Deleted " $File.FileName
