[Bug/6.3.1/Win11] Main window "disabled" after cancelling connection
FearDC
FearDC avatar
Sweden
Usually connecting to a site goes fast, but in my case the FTPS server is misconfigured. When WinSCP enters "reading remote directory" timeout, which is 30 seconds, there is plenty of time to press X – close button. Once status "cancelling" appears and connection window closes, main window can no longer be accessed, it stays "disabled" until I kill and restart application.
Re: [Bug/6.3.1/Win11] Main window "disabled" after cancelling connection
FearDC
FearDC avatar
Sweden
There is no crash, no high CPU usage. The window simply stays frozen. I'm not sure how debug version will help.
In Windows there is something called "stay on top", which disables background windows while foreground window is active. In this case, the background window is never unlocked. Simply.
Team Elite
I understand. The log would have helped anyway.
Though I was able to reproduce the problem myself in the end.
I identified two problems.
I believe that yours is this one:
Issue 2266 – Hang when canceling connection while reading remote directory
And there's another one:
Issue 2267 – Failure when canceling FTP connection while reading remote directory
I'm sending you an email with a development version of WinSCP.
