Multiple connections in one bat file
I did have this working and then made some changes and don't know what has made it no longer work properly:
I have tried using sessions and I have tried just going with simple commands. I have tried with the built in copy script and nothing is letting it proceed to the second and further maps in one bat file.
I have tried it with the
The following is edited removing the identifiers for the servers and host.
Can someone please tell me what I have done that is making it so that only one server backs up and then closes?
"close"/echo close inbetween each server and I have tried it as it is written below. What is happening now is that the bat is running bottom to top and I only get one server backing up and then the prompt just returns to a new prompt.
set path=F:\"Testing Bat" F: cd %path% set name1=%date1%"Maps" set name2=%path%\%date1%" Maps" set password=<password> set scriptfile=%temp%\ARK.txt echo open ftpes://<id>:%password%@<host> -rawsettings ProxyPort=0 >%scriptfile% echo cd /arksa/ShooterGame/Saved/SavedArks/TheIsland_WP >>%scriptfile% echo lcd %name2%\TheIsland\SavedArks >>%scriptfile% echo get *.(file) >>%scriptfile% echo cd /arksa/ShooterGame/Saved/Config/WindowsServer >>%scriptfile% echo lcd %name2%\TheIsland\Config >>%scriptfile% echo get Game.ini >>%scriptfile% echo get GameUserSettings.ini >>%scriptfile% echo close >>%scriptfile% echo open ftpes://<id>:%password%@<host> -rawsettings ProxyPort=0 >%scriptfile% echo cd /arksa/ShooterGame/Saved/SavedArks/TheIsland_WP >>%scriptfile% echo lcd %name2%\TheSecondIsland\SavedArks >>%scriptfile% echo get *.(file) >>%scriptfile% echo cd /arksa/ShooterGame/Saved/Config/WindowsServer >>%scriptfile% echo lcd %name2%\TheSecondIsland\Config >>%scriptfile% echo get Game.ini >>%scriptfile% echo get GameUserSettings.ini >>%scriptfile% echo close >>%scriptfile% echo exit mkdir %name2% cd %name2% mkdir TheIsland mkdir TheIsland\Config mkdir %name2% cd %name2% mkdir TheSecondIsland mkdir TheSecondIsland\Config
