Multiple Attributes -append AND then -delete
LEMS
Georgia
I would like to append the data to the file then delete the source file. It seems to only handle one attribute at a time and ignoring the other. I either get the delete or the append ... not both. Suggestions?
Re: Multiple Attributes -append AND then -delete
Works for me. Please attach a full session log file showing the problem (using the latest version of WinSCP).
