Cannot enter Host name in format of this@that@other
harryc
Chicago
Running WinSCP 6.3.1
Using site manager to enter a new or edit an existing site, I cannot enter a host name which is in the format this@that@other. The screen strips off this@that as the User name and leaves only other as the Host name. I can find no way to edit this such that I can enter this entire string in the Host name, and an unrelated string (e.g. my_user) as the User name.
Is there a workaround to override this behavior? Maybe an option to shut it off?
Thank you!
Re: Cannot enter Host name in format of this@that@other
How did you get to the format this@that@other? Valid characters in hostname are only letters, digits, hyphen and dots.
