How to sync folders between local drives?
Radiant
I have read through the wiki for synchronizing, and I saw this post External harddrive sync asking for the feature to sync between two local drives with a response linking it to this tracker which has been implemented Issue 1893 – Local file manager mode (two local panels).
However, If I connect to a remote host I can sync but when I have two panes open for a local drive the Synchronize button is just greyed out.
I can drag files between the panes for the local drives but I want to use the sync function.
Is this actually possible in WinSCP?
I am using WinSCP 6.3.1 on Windows 10.
Radiant
