Custom Login Commands
Is there a way to send custom login commands to a device on connect? I'm attempting to use SCP for access to routers but on connect with SSH, the router goes to the router software prompt and I believe that's why it's getting stuck at "Starting the session". The start shell command has to be entered at the prompt to access the bash shell.
