Timeout setting not working
pantos21
Hi all,
I run the following commands to upload files to many SFTP servers but the /timeout=5 option is not working and the session just get stuck when one server is not available. any help is appreciated.
"C:\Program Files (x86)\WinSCP\WinSCP.com" /ini=nul /script=C:\test\script1.txt sftp://tester:password@192.168.30.2  /timeout=5 /hostkey=*
"C:\Program Files (x86)\WinSCP\WinSCP.com" /ini=nul /script=C:\test\script1.txt sftp://tester:password@192.168.30.1  /timeout=5  /hostkey=*
"C:\Program Files (x86)\WinSCP\WinSCP.com" /ini=nul /script=C:\test\script2.txt sftp://tester:password@192.168.79.3  /timeout=5  /hostkey=*
Regards
Pantelis komatas
Re: timeout setting not working
