What is the correct syntax to use WinSCP SFTP script
support@overseas.be
IT Support
We are struggling to find out the correct syntax for a SFTP script.
We started with the generated syntax:
/log="C:\writable\path\to\log\WinSCP.log" /ini=nul /command "open sftp://XXX:pwd@site:7805/ -hostkey=""ssh-rsa 2048 generated_hostkey""" "Your command 1" "Your command 2" "exit"
We receive error:
Server offered these authentication methods: publickey
No supported authentication methods available (server sent: publickey)
Attempt to close connection due to fatal exception:
We also tried to add extra parameters to the command:
winscp.exe /ini=nul /log="path\logfile" /command "open sftp://XXX:pwd@site:7805/ -hostkey=""ssh-rsa 2048 generated_hostkey"" -privatekey=""path to Private key.ppk"" -clientcert=""pzth to client certificate"" -passphrase=""password of certificate""" "exit"
Thanks for your feedback!
Re: What is the correct syntax to use WinSCP SFTP script
So what authentication are you supposed to use? Password or private key? Or both? Does the connection work in GUI? Please post log from the script (and from the GUI, if the authentication works there).
