Configuring "Advanced Site Settings" via command line
When I use the WinSCP GUI, I am able to log in with root permissions by going to the "Advanced Site Settings > SFTP" and putting
In command line I navigate to where WinSCP is housed (
When logging in via GUI with the Advanced Site Settings configured, I'm able to do everything with root permissions. When running the above commands in command line, permission is denied. I should specify that the username, password, and IP address I'm using to log in are the same for the GUI and the command line. Is there a way to get the "Advanced Settings" configured in the same way while logging in via command line. I need root privileges to run certain commands via command line.
doas /usr/libexec/sftp-server
in the box next to "SFTP server:". I've attached an image of this configuration. I am attempting to replicate this setting in the Windows command line, but have found no resources to help with this.
C:\Program Files (x86)\WinSCP
) and run this command format:
winscp.com /command "open sftp://USER:PASSWORD@IPADDRESS" "command 1" "command 2" "exit"
