Servers sent passive reply with unroutable Address
ksakellakos
Greece
Dear support team,
I get an error
Server sent passive reply with unroutable address 10.0.0.4 using host address instead
Inside error reads
SSL3 alert write: fatal:decrypt error
digest check failed
TLS connect: error in error
Cannot establish TLS connection
Copying files from remote site failed
I have created in my firewall a separate rule with destination port 62990 and removed any kind of inspection to avoid encryption errors. Policy matches the traffic but I still have same mistake
Also from time to time after 5–10 tries the connection is established (although file copy fails).
Description: log attached
