- Guest
Website not acessible from Turkey
The website gets "ERR_CONNECTION_REFUSED" error when it's opened from Turkey.
brablc◆
Moderator -
- 13
- Praha, Czech Republic
Re: Website not acessible from Turkey
Please anyone, who will come across this post and is from Turkey and has the same problem, get in contact with us. We can see, that there was a sudden decline of visits about a year ago (April 2023), part of the problem was mobile ISP's blocking CDN77 which we use. We have disabled CDN usage for Turkey and serve the content completely from our main server directly. But apparently there are more problems ;-(
iugurbas
I can not access too.
- reeder
- 3
- Turkey
Cannot access winscp.net from Turkey
Problem still exists, is there a IP ban for the connections coming Turkey ?
We can only access through the VPN, what is the problem ?
Turkey access problem.
Problem resolved, thanks.
jewoper2
Problem still exist. We can connect only VPN.
TURKSAT ISP (my office) not connect.
TURKNET ISP (my home) not connect.
VODAFONE ISP (my home) can connect
brablc◆
Moderator -
Verify access over CloudFlare proxy
Can you please check your access over beta.winscp.net domain? It will not work for other links from the page, but we will be able see if proxying thru CloudFlare proxy helps in your case to make other adjustments.
- BRT
- 2
- Türkiye
Hello, I'm writing from Türkiye. When I remove
In the same way, I can access the download page by using
To be able to write this message, I also had to access your website using a VPN. For your information.
LOGIN ERROR
DOWNLOAD ERROR
https:// and use beta., I can access the homepage and the forum homepage, but when I try to log in by entering my username, I get an error like the ones shown in the screenshots below.
beta., but the download does not start automatically on that page. When I click the Direct Download button, I get the same error. However, if I remove https:// from the link on the newly opened download page and replace it with beta., the file starts downloading.
LOGIN ERROR
DOWNLOAD ERROR
brablc◆
Moderator -
Thanks for your test! This is expected behavior at this point. We would have to make a lot of changes to make it work completely (do not want to rely on Cloudflare) but we needed this test before.
You're welcome, I'm glad if I could help. Thank you for providing us with such a nice and high-quality program.
By the way, we can’t attach more than three files to the forum, so when I had four images, I had to upload them to an external source. In the future, the images might turn into frogs 🙂
- reeder
- 3
- Turkey
We cannot access from Turkey, did the developer wanted to ban Turkey ?
brablc◆
Moderator -
- 13
I was in Turkey this year and was testing the accessibility of our server. And indeed the Turk Telekom (and this is the only provider of fixed internet I saw on any wifi I tested) is blocking our IP address (all ports).
I have improved how we proxy https://beta.winscp.net/ and it should now be more stable. Can you try? If this works, we will make this domain better searchable for people looking from Turkey.
