FileMask problem with includes and excludes directories
Joe78
Thank you very much for the great .NET assembly.
Unfortunately, I am having trouble with a rather complicated mask.
The folder structure from which synchronization should occur is as follows:
I:\project\2020\001__Projectname1\subfolder1\subfolder2
I:\project\2020\002__Projectname2\subfolder1\subfolder2
I:\project\2020\003__Projectname3\subfolder1\subfolder2
I:\project\2021\001__Projectname4\subfolder1\subfolder2
I:\project\2021\002__Projectname5\subfolder1\subfolder2
I:\project\2021\003__Projectname6\subfolder1\subfolder2
I actually have yearly folders from 2014–2024, and each year contains around 300 project folders. My program provides me with a list of about 50 folders from different years that I want to synchronize, but only those specific ones. So, I wanted to recursively include these parts of the path names, which are unique (e.g., 003__Projectname6), as directories to be considered. Additionally, I do not want to synchronize any files with some specific endings and do not want to synchronize any subfolder1 named MB-Projekt
The synchronization starts at I:\project.
opt = new TransferOptions();
opt.FileMask =  "*\002__Projectname2\; *\003__Projectname6\; | *.DMX; *.vps; *.ini; *.lock; */MB-Projekt/";
Unfortunately, there are issues with the directory being considered. While this directory is synchronized, its subdirectories and their files are not. How can I achieve this?
Re: FileMask problem with includes and excludes directories
With your file mask, I would expect nothing to be synchronized, as you are implicitly excluding the root year folders.
Joe78
Log-File
Actually, you are right, and thanks for the tip about the log file. I have adjusted the mask again. Now it synchronizes, but I can't manage to exclude the subfolder MB-Projekt. What else do I need to change?
opt.FileMask = "*/101__Projectname1/*/*; */119__Projectname2/*/* | *.DMX; *.vps; *.ftz; *.old; *.*.jpeg; *.doc; *.docx; *.ini; *.lock; ./Projekte/????/*/MB-Projekt/*"
Attached the log.file.
  • log.txt (877.5 KB, Private file)
Re: Log-File
The root of your synchronization is the Projekte folder. The ./Projekte/????/*/MB-Projekt/* is resolved relatively to that. So it refers to non-existing Projekte/Projekte folder. The file mask should be ./????/*/MB-Projekt/*
Joe78
Re: Log-File
thanks, but unfortunately, didn't help so far.
Attached the new log file.
It still syncronizes the MB-Projekte folder with all its subfolders.
Any other idea how the mask should be?
  • log1.txt (4.65 MB, Private file)
Re: Log-File
Thanks. I cannot reproduce the behaviour you are seeing.
Let's start here:
. Local file 'I:\Projekte\2014' [2018-12-28T12:30:39.108Z] [0] excluded from synchronization
. Local file 'I:\Projekte\2015' [2021-07-23T12:33:13.342Z] [0] excluded from synchronization
. Local file 'I:\Projekte\2016' [2020-04-20T10:45:14.830Z] [0] excluded from synchronization
. Local file 'I:\Projekte\2017' [2023-01-02T09:46:54.952Z] [0] excluded from synchronization
. Local file 'I:\Projekte\2018' [2019-08-02T04:54:43.637Z] [0] excluded from synchronization
. Local file 'I:\Projekte\2019' [2020-05-26T13:43:09.017Z] [0] excluded from synchronization
. Local file 'I:\Projekte\2020' [2022-05-30T06:58:38.637Z] [0] excluded from synchronization
. Local file 'I:\Projekte\2021' [2023-09-26T13:16:15.212Z] [0] included to synchronization
. Local file 'I:\Projekte\2022' [2022-12-21T14:57:50.246Z] [0] included to synchronization
. Local file 'I:\Projekte\2023' [2023-12-22T08:56:32.548Z] [0] included to synchronization
. Local file 'I:\Projekte\2024' [2024-05-17T11:51:40.437Z] [0] included to synchronization
. Local file 'I:\Projekte\DATA' [2024-03-06T09:35:29.387Z] [0] excluded from synchronization
Is it intentional that 2021–2024 are included, while 2015–2020 are not? I do not see what causes that. For me, all year folders are excluded. And that's the behaviour I'd expect, because your mask still implicitly exclude all of them.
Joe78
Re: Log-File
Yes, and thank you for sticking with it.
The fact that only the years 2021–2024 are included is indirectly caused by the allowed (sub)directories, which only occur in the years 2021–2024 (see the very beginning of the fileMask settings).
At the timestamp 2024-05-21 11:15:13.175, 4 directories are listed that are in the 2021 year folder and match the fileMask settings at the beginning. However, at the timestamp 2024-05-21 11:15:13.508, the subfolder ..\MB-Projekt is taken into account, which is incorrect due to the excluding conditions at the end of the fileMask settings.
Re: Log-File
But it doesn't work like that. Every folder level is evaluated independently.
WinSCP does not care what subfolders exist under 2021, when deciding if it should synchronize it.
