"Invalid access to memory" with SynchronizationCriteria.Checksum
geek569
session.SynchronizeDirectories(SynchronizationMode.Remote, @"D:\test\", "/test", true, mirror: true, criteria: SynchronizationCriteria.Checksum);
this above code throws:
Error: WinSCP.SessionRemoteException: Invalid access to memory. at WinSCP.OperationResultBase.Check()
the exception is gone by removing
Re: "Invalid access to memory" with SynchronizationCriteria.Checksum
geek569
I'm using NuGet but the v6.4 not published yet.
I tried to overwrite WinSCP.exe and WinSCPnet.dll but I got:
Method not found: 'Void System.Threading.EventWaitHandle..ctor(Boolean, System.Threading.EventResetMode, System.String, Boolean ByRef, System.Security.AccessControl.EventWaitHandleSecurity)'.
That means your SFTP server does not support checksums. And you also do not have a shell access, so WinSCP cannot use a fallback mechanism of calculating checksums using shell commands.
