HTTP result code 302 while trying to transfer WebDAV content from host to local folder
klinius
I am using the WinSCP .NET NuGet package in a 4.72 .NET framework application. This application uses WebDAV to transfer host files to a machine local directory, renames the file, and then transfers it back to a different remote directory of the same host. The WebDavSessionOptions.HostName was miskatonic.edu. The WebDavSessionOptions.RootPath was /bbcswebdav.
All was working well until the host implemented an "alternate directory" security feature. Now, attempts to download files result in a SessionRemoteException error. Example:
WinSCP.SessionRemoteException: Error transferring file '/bbcswebdav/courses/FIN505.1.FALL2023WEBSTER/syllabus.pdf'. WebDAV resource moved to 'https://alt-domain.blackboard.com/bbcswebdav/courses/FIN505.1.FALL2023WEBSTER/syllabus.pdf?source_domain=miskatonic.edu' 302
I'm at a loss. How do I instruct the WinSCP .NET connection to honor the 302 redirection? Connection open and authentication only works if I stay with miskatonic.edu as the host name. The configured host name is used to form the download link. Attempts to use the alt-domain link as part of the download results in 501 errors.
How do I download files from the redirected directory?
Re: HTTP result code 302 while trying to transfer WebDAV content from host to local folder
klinius
Log Files
Attaching WinSCP and Application log files.
I did alter private information without destroying log meaning.
  • AppLog.txt (1.54 KB, Private file)
Description: Application Log
  • WinScpLog.txt (159.84 KB, Private file)
Description: Win SCP Log
klinius
How to change answer from Abort to "Accept" ?
These appear to be the pertinent log lines:
* 2024-05-30 07:13:10.187 Redirected to "https://alt-UniqueReference.blackboard.com/bbcswebdav/courses/FIN505.1.FALL2023SIMON/syllabus.pdf?source_domain=uroc-livemig.blackboard.com".
* 2024-05-30 07:13:10.188 (ExtException) WebDAV resource moved to 'https://alt-UniqueReference.blackboard.com/bbcswebdav/courses/FIN505.1.FALL2023SIMON/syllabus.pdf?source_domain=uroc-livemig.blackboard.com'.
* 2024-05-30 07:13:10.188 302
. 2024-05-30 07:13:10.188 Asking user:
. 2024-05-30 07:13:10.188 Error transferring file '/bbcswebdav/courses/FIN505.1.FALL2023SIMON/syllabus.pdf'. ("WebDAV resource moved to 'https://alt-UniqueReference.blackboard.com/bbcswebdav/courses/FIN505.1.FALL2023SIMON/syllabus.pdf?source_domain=uroc-livemig.blackboard.com'.","302 ")
< 2024-05-30 07:13:10.188 Script: Error transferring file '/bbcswebdav/courses/FIN505.1.FALL2023SIMON/syllabus.pdf'.
< 2024-05-30 07:13:10.188 Script: WebDAV resource moved to 'https://alt-UniqueReference.blackboard.com/bbcswebdav/courses/FIN505.1.FALL2023SIMON/syllabus.pdf?source_domain=uroc-livemig.blackboard.com'.
< 2024-05-30 07:13:10.188 302
. 2024-05-30 07:13:10.189 Answer: Abort
What should be done to change the answer from Abort to Accept?
klinius
Success! Thank you
Martin,
The development version which you provided resolved the remote to local transfer problem. It was also used to transfer local to remote.
I've uploaded a WinSCP log of the session.
Thank you!
Richard
amranthf
[quote="martin"]Thanks.
I have added this issue to the tracker:
[url*]https://winscp.net/tracker/2293[/url]
I'm sending you an email with a development version of WinSCP to the address you have used to register on this forum.[/quote]
Hi martin, could you please send me the development version? I need the bug-fixed version to download files.
