Network drive cannot be mounted with PowerShell
I would like to transfer data using WinSCP in a PowerShell script.
The connection can be established and the transfer works.
But now I want the following...
The target server has a network drive mounted. On this drive the data should be transferred.
I try to mount the network drive using
If I establish the connection using the WinSCP GUI and open PuTTY the network drive can be mounted.
Can anyone help me?
net use but I get the message that the drive cannot be mounted and the script stops.
Can anyone help me?
Add-Type -Path "C:\Program Files (x86)\WinSCP\WinSCPnet.dll" $sessionOptions = New-Object WinSCP.SessionOptions -Property @{ Protocol = [WinSCP.Protocol]::Sftp HostName = "" UserName = "" Password = "" SshHostKeyFingerprint = "" SshPrivateKeyPath = "" } $session = New-Object WinSCP.Session try { $session.Open($sessionOptions) if ($session.Opened) { $netUseResult = net use K: \\test\abc if ($netUseResult -like "*successful*") { $transferOptions = New-Object WinSCP.TransferOptions $transferOptions.TransferMode = [WinSCP.TransferMode]::Binary $transferResult = $session.PutFiles("C:\Temp\Test\*", "K:/abc", $False, $transferOptions) $transferResult.Check() foreach ($transfer in $transferResult.Transfers) { Write-Host "Upload $($transfer.FileName) successful." } } else { Write-Host "Network drive could not be connected." } } else { Write-Host "Connection to WinSCP could not be established." } } catch { Write-Host "An error has occurred: $($_.Exception.Message)" } finally { $session.Dispose() if ($netUseResult -like "*successful*") { net use K: /delete } }
