To resolve error "Could not agree host key algorithm" while scripting PowerShell using .NET assembly
vyom
Hi, Greetings!!!
I am new to PowerShell scripting and WinSCP as well. My scenario is to compare timestamp off two files from two different directories from WinSCP. Hence I started first making connection with server using PowerShell which is generated by .NET assembly of WinSCP using below code.
WinSCP version is 6.3.1
However, I am getting below error
Error : Exception calling "Open" with "1" arguments(s): " Could not agree host key algorithm" (available: rsa-sha2-XXX,rsa-sha2-256)
try
    # Load WinSCP .NET assembly
    Add-Type -Path "WinSCPnet.dll"
    # Setup session options
        HostName = "example.com"
        UserName = "user"
        Password = "mypassword"
        SshHostKeyFingerprint = "ssh-rsa 2048 xxxxxxxxxxx..."
    try
        # Connect
        # code for comparing timestamp
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch
    exit 1
Kindly help me in resolving this error.
Re: To resolve error "Could not agree host key algorithm" while scripting PowerShell using .NET assembly
Can you connect in WinSCP GUI? Please post logs both from the GUI and the .NET assembly.
