Can't connect to my SharePoint folder through WebDAV
MCorbo
Uruguay
Greetings.
I have 2FA enabled on my account so I had to set an app password to connect, I verified this works if I connect through Windows Explorer, but I need to use WinSCP. Here's my log:
. 2024-06-14 11:21:58.768 --------------------------------------------------------------------------
. 2024-06-14 11:21:58.768 Session name: username@xxx.xx@tenantxxx.sharepoint.com (Ad-Hoc site)
. 2024-06-14 11:21:58.768 Host name: tenantxxx.sharepoint.com (Port: 443)
. 2024-06-14 11:21:58.768 User name: username@xxx.xx (Password: Yes, Key file: No, Passphrase: No)
. 2024-06-14 11:21:58.768 Transfer Protocol: WebDAV
. 2024-06-14 11:21:58.768 Proxy: None
. 2024-06-14 11:21:58.768 HTTPS: Yes [Client certificate: No]
. 2024-06-14 11:21:58.768 WebDAV: Tolerate non-encoded: No
. 2024-06-14 11:21:58.768 TLS/SSL versions: TLSv1.2-TLSv1.3
. 2024-06-14 11:21:58.768 Local directory: default, Remote directory: /sites/mcorbo/username/, Update: Yes, Cache: Yes
. 2024-06-14 11:21:58.768 Cache directory changes: Yes, Permanent: Yes
. 2024-06-14 11:21:58.768 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2024-06-14 11:21:58.768 DST mode: Unix
. 2024-06-14 11:21:58.768 Compression: No
. 2024-06-14 11:21:58.819 HTTP session to https://tenantxxx.sharepoint.com:443 begins.
. 2024-06-14 11:21:58.820 ssl: SNI enabled by default.
. 2024-06-14 11:21:58.820 auth: Create for WWW-Authenticate
. 2024-06-14 11:21:58.820 Sending request headers:
. 2024-06-14 11:21:58.820 OPTIONS /sites/mcorbo/username/ HTTP/1.1
. 2024-06-14 11:21:58.820 User-Agent: WinSCP/6.3.3 neon/0.33.0
. 2024-06-14 11:21:58.820 Keep-Alive:
. 2024-06-14 11:21:58.820 Connection: TE, Keep-Alive
. 2024-06-14 11:21:58.820 TE: trailers
. 2024-06-14 11:21:58.820 Host: tenantxxx.sharepoint.com
. 2024-06-14 11:21:58.820 Sending request-line and headers:
. 2024-06-14 11:21:58.821 Doing DNS lookup on tenantxxx.sharepoint.com...
. 2024-06-14 11:21:58.912 req: Connecting to 13.107.138.10:443
. 2024-06-14 11:21:58.926 Doing SSL negotiation.
. 2024-06-14 11:21:59.020 Identity match for 'tenantxxx.sharepoint.com': good
. 2024-06-14 11:21:59.020 Verifying certificate for "Microsoft Corporation, Redmond, WA, US" with fingerprint a1:a3:8b:98:e9:eb:2c:4a:ec:f1:da:7e:3a:8b:88:45:07:10:37:6d:29:e4:3d:d6:aa:93:db:da:0f:86:a6:2d and 08 failures
. 2024-06-14 11:21:59.043 Certificate verified against Windows certificate store
. 2024-06-14 11:21:59.043 Using TLSv1.2, cipher TLSv1.2: ECDHE-RSA-AES256-GCM-SHA384, 2048 bit RSA
. 2024-06-14 11:21:59.043 Request sent; retry is 0.
. 2024-06-14 11:21:59.301 [status-line] < HTTP/1.1 403 FORBIDDEN
. 2024-06-14 11:21:59.301 Header Name: [content-length], Value: [13]
. 2024-06-14 11:21:59.301 Header Name: [content-type], Value: [text/plain; charset=utf-8]
. 2024-06-14 11:21:59.301 Header Name: [p3p], Value: [CP="ALL IND DSP COR ADM CONo CUR CUSo IVAo IVDo PSA PSD TAI TELo OUR SAMo CNT COM INT NAV ONL PHY PRE PUR UNI"]
. 2024-06-14 11:21:59.301 Header Name: [x-networkstatistics], Value: [0,525568,0,143,4060351,0,525568,140]
. 2024-06-14 11:21:59.301 Header Name: [x-sharepointhealthscore], Value: [0]
. 2024-06-14 11:21:59.301 Header Name: [x-databoundary], Value: [NONE]
. 2024-06-14 11:21:59.301 Header Name: [x-1dscollectorurl], Value: [https://mobile.events.data.microsoft.com/OneCollector/1.0/]
. 2024-06-14 11:21:59.302 Header Name: [x-ariacollectorurl], Value: [https://browser.pipe.aria.microsoft.com/Collector/3.0/]
. 2024-06-14 11:21:59.302 Header Name: [sprequestguid], Value: [d39432a1-a045-5000-a290-5884a12e20a4]
. 2024-06-14 11:21:59.302 Header Name: [request-id], Value: [d39432a1-a045-5000-a290-5884a12e20a4]
. 2024-06-14 11:21:59.302 Header Name: [ms-cv], Value: [oTKU00WgAFCikFiEoS4gpA.0]
. 2024-06-14 11:21:59.302 Header Name: [x-forms_based_auth_required], Value: [https://tenantxxx.sharepoint.com/_forms/default.aspx?ReturnUrl=/_layouts/15/error.aspx&Source=/sites/mcorbo]
. 2024-06-14 11:21:59.302 Header Name: [x-forms_based_auth_return_url], Value: [https://tenantxxx.sharepoint.com/_layouts/15/error.aspx]
. 2024-06-14 11:21:59.302 Header Name: [x-msdavext_error], Value: [917656; Access+denied.+Before+opening+files+in+this+location%2c+you+must+first+browse+to+the+web+site+and+select+the+option+to+login+automatically.]
. 2024-06-14 11:21:59.302 Header Name: [x-idcrl_auth_params_v1], Value: [IDCRL Type="BPOSIDCRL", EndPoint="/sites/mcorbo/_vti_bin/idcrl.svc/", RootDomain="sharepoint.com", Policy="MBI"]
. 2024-06-14 11:21:59.302 Header Name: [x-powered-by], Value: [ASP.NET]
. 2024-06-14 11:21:59.302 Header Name: [microsoftsharepointteamservices], Value: [16.0.0.24929]
. 2024-06-14 11:21:59.302 Header Name: [x-content-type-options], Value: [nosniff]
. 2024-06-14 11:21:59.302 Header Name: [x-ms-invokeapp], Value: [1; RequireReadOnly]
. 2024-06-14 11:21:59.302 Header Name: [x-cache], Value: [CONFIG_NOCACHE]
. 2024-06-14 11:21:59.302 Header Name: [x-msedge-ref], Value: [Ref A: 388B2BBD5AC84B3B9A343AC74FA129E6 Ref B: BUE30EDGE0309 Ref C: 2024-06-14T14:21:55Z]
. 2024-06-14 11:21:59.302 Header Name: [date], Value: [Fri, 14 Jun 2024 14:21:54 GMT]
. 2024-06-14 11:21:59.302 End of headers.
. 2024-06-14 11:21:59.302 auth: Post-send (#0), code is 403 (want 401), WWW-Authenticate is (none)
. 2024-06-14 11:21:59.302 Request ends, status 403 class 4xx, error line:
. 2024-06-14 11:21:59.302 403 FORBIDDEN
. 2024-06-14 11:21:59.302 Request ends.
. 2024-06-14 11:21:59.302 sess: Destroying session.
. 2024-06-14 11:21:59.302 sess: Closing connection.
. 2024-06-14 11:21:59.302 ssl: Shutdown state: not sent | not received.
. 2024-06-14 11:21:59.302 ssl: Sending closure.
. 2024-06-14 11:21:59.302 sess: Connection closed.
* 2024-06-14 11:21:59.350 (EFatal) 403 FORBIDDEN
