Drag and drop behaviour from WinSCP to Outlook message
When dragging and dropping from the WinSCP client to a message in Outlook the file gets moved from the source instead of copying the file to the message. It is somewhat counterintuitive for me when the default behaviour is a copy when dragging from WinSCP to a local folder on Windows.
Best regards Morten
Version of WinSCP: 6.1.1
Windows 10 Enterprise 22H2
Transfer protocol: SFTP
The behaviour is the same in both commander and explorer.
- Is this behaviour intentionally?
- Is it possible to change this behaviour in the settings? I am aware that you can force it to copy by holding down
Controlbut is possible to make it the default behaviour?
Best regards Morten
