probleme .filepart
Hello, I hope you are doing well.
I have a problem with WinSCP. WinSCP adds the extension
Here are the recent logs:
.filepart to our files when we transfer them from our server to another server. We are using WinSCP version 5.21.5 on Windows.
> 2024-06-25 15:10:28.085 Type: SSH_FXP_RENAME, Size: 124, Number: 3346 < 2024-06-25 15:10:29.132 Type: SSH_FXP_STATUS, Size: 207, Number: 3346 < 2024-06-25 15:10:29.132 Status code: 4, Message: 3346, Server: Resource busy. Failed to rename /xxxxx/xxxxxx/xxx/xxxxxxxxxx.filepart to /xxxxxxxxx/xxxxxxx/xxx/xxxxxxxxx because the file is currently in progress., Language: * 2024-06-25 15:10:29.132 (ETerminal) General failure (server should provide error description). * 2024-06-25 15:10:29.132 Error code: 4 * 2024-06-25 15:10:29.132 Error message from server: Resource busy. Failed to rename /xxxxxxxxx/xxxxxxx/xxx/xxxxxxxxx .filepart to /xxxxxxxxx/xxxxxxx/xxx/xxxxxxxxx because the file is currently in progress. * 2024-06-25 15:10:29.132 * 2024-06-25 15:10:29.132 Common reasons for the Error code 4 are: * 2024-06-25 15:10:29.132 - Renaming a file to a name of already existing file. * 2024-06-25 15:10:29.132 - Creating a directory that already exists. * 2024-06-25 15:10:29.132 - Moving a remote file to a different filesystem (HDD). * 2024-06-25 15:10:29.132 - Uploading a file to a full filesystem (HDD). * 2024-06-25 15:10:29.132 - Exceeding a user disk quota. . 2024-06-25 15:10:29.132 Asking user: . 2024-06-25 15:10:29.132 Transfer was successfully finished, but temporary transfer file '/xxxxxxxxx/xxxxxxx/xxx/xxxxxxxxx.filepart' could not be renamed to target file name '/xxxxxxxxx/xxxxxxx/xxx/xxxxxxxxx '. If the problem persists, you may try to turn off transfer resume support. ("General failure (server should provide error description). . 2024-06-25 15:10:29.132 Error code: 4
