Script encountering authentication issues with WebDAV server (Outlook.com)
jdProm
I am trying to transfer SQL files from a local folder to OneDrive using WinSCP with the following batch script:
@echo off
  /command ^
    "open davs://transferTest@outlook.com:mypassword@d.docs.live.net/96CD15E62736DEE8/Dokumenti/IzvozPodataka" ^
    "put C:\izvoz\*.sql" ^
    "exit"
if %WINSCP_RESULT% equ 0 (
  echo Success
) else (
  echo Error
But I get the following error:
Connecting to host...
Authenticated.
Starting the session...
Error changing directory to '/96CD15E62736DEE8/Dokumenti/IzvozPodataka'.
Authentication failed.
Could not authenticate to server: ignored Wlid1.1 challenge
Error
Press any key to continue . . .
I have double-checked the username and password, and they are correct. Can you tell me where the problem might be? The script was running smoothly until about two weeks ago (with the same credentials). As a test, I rewrote this script to upload files to another OneDrive account, and it worked properly. Is there possibly a problem with the account transferTest@outlook.com?
Thank you!
Re: Script encountering authentication issues with WebDAV server (Outlook.com)
Can you post session log files for both accounts?
Can you login using the transferTest from WinSCP GUI?
jdProm
WINSCP GUI
Yes, I can log in to this account via WinSCP GUI, but when I try to transfer a file from a local folder to the IzvozPodataka folder on OneDrive, I get a '403 Forbidden' error.
RandomUser447
I have the same issue
After I updated the OneDrive application on my Android phone I started to have the same issue with the WebDAV connection in WinSCP.
I still didn't found a solution until now.
gholmann
Same issue here
I'm having the same error when trying to upload files from local to OneDrive / WebDAV. Has anyone found a solution?
Re: Same issue here
Do you mean that you can login and browse folders, but you cannot upload? Anywhere? Or to some specific folders only?
CodeGnome
I have the same problem
I can browse all directories in the GUI, but I get the error message
when I try to upload a file.
j150us
I get exact same error when accessing OneDrive from WinSCP
If I click OK all files and directories are displayed except for parent directory name appears among other directories and there is no parent directory icon with an arrow on it and two dots to navigate to parent directory.
If I click parent directory name that appears among the names of its subdirectories I get error message:
Error changing directory to [parent directory name].
I can still download files but If I try to upload something I get error message "Authentication failed".
  • WinSCP_OneDrive_Error.png (6.05 KB, Private file)
@j150us: Is it regular/personal OneDrive? Or some business account? Or some Sharepoint?
mr_bartleboom
I got the same error after months (!!) of successfully uploads using .net.
If I access using the GUI now the root directory shows a subdirectory with the same name (CID).
Also inside the directory where I copied to several times now there is a subdirectory with the same name. If I try to delete the directory it says access forbidden.
Attached the logs
Description: Logs
Re: Could not authenticate to server: ignored Wlid1.1 challenge
@mr_bartleboom: I do not see any "Could not authenticate to server: ignored Wlid1.1 challenge" in your log. Are you sure you have posted the right log?
mr_bartleboom
@martin
Sorry for the long time passed, yes my bad I uploaded the wrong log file.
I try to explain better, I got the error "Could not authenticate to server: ignored Wlid1.1 challenge" using the GUI interface OR the .NET library. After the error, navigating the folders I got a double root CID folder, also my sub folder AC_UPLOAD duplicate it self inside. If I try to delete/navigate the duplicate folders I got "Not found 404".
Instead, using the command line for uploading a file I get a "403 Forbidden", see attached log.
Many thanks for your help and your work.
Description: test files
@mr_bartleboom: Please post log on normal logging level.
And also the log from the GUI for the "ignored Wlid1.1 challenge".
mr_bartleboom
Dear @Martin
thank you for your help, here enclosed the 2 logs.
  • Logs.zip (19.04 KB, Private file)
@mr_bartleboom: The server returns:
Access denied. Before opening files in this location you must first browse to the web site and select the option to login automatically
This page:
Microsoft Error - Access denied. Before opening files in this location, you must first browse to the web site and select the option to login automatically.
suggests:
Here is the fix that worked for me:
Browse to https://"YourOrganization"-admin.sharepoint.com/
Policies > Access Control
Change the "Apps that don't use modern authentication" to Allow Access
@martin: I'm a bit confused..my outlook.com account is a private account (free) and I don't have idea which is my "YourOrganization"-admin... any suggestion?
I was testing this yesterday using multiple accounts, both old and new, both with two-factor authentication on and off. All was working.
And suddenly, today, I'm getting the same symptoms as mr_bartleboom for all of them.
Something must have changed overnight. Seeing lot of differences between how the server was responding yesterday and how it is today, my accounts must have been migrated to some kind of new server. Seeing new EU-related headers, I wonder if this is about EU Data Residency regulation. Aren't you all located in EU? I also wonder, if migration might have been triggered by my tests earlier (as I did login to my OneDrive in web browser the first time after months, if not years).
Anyway, I've made basic improvements to make WinSCP compatible with the new server/interface.
But I at least know about one more problem with creating new folders – to be solved the next week.
Issue 2321 – Compatibility with new OneDrive WebDAV interface
@mr_bartleboom: Can you send me an email, so I can send you back a development version of WinSCP for testing? Please include a link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
mr_bartleboom
Italy
Yes, I confirm I am locate inside EU.
I just sent you my email address, thank you for your work and help.
