Merging Remote Folders is not implemented
Operation
Renaming remote folder from name
Version
WinSCP 6.3.4
Current Behavior
folder1 to name folder2, with two previously existing remote folders folder1 and folder2.
Version
WinSCP 6.3.4
Current Behavior
- A Dialog with the deletion operation appears
folder2is deleted
folder1is renamed asfolder2
- A Dialog with the merge operation appears, asking the files which will be overwritten
folder1is merged intofolder2
folder1 into folder2, and asking for renaming when identical names exist, like Windows Merge Explorer or rsync Merge functionalities.
