Main Window Opens Unmaximized If Closed from System Tray on Transfer completion
war59312
U.S.A
The Main Window Opens Unmaximized If Closed from System Tray on Transfer completion
That is enabling: "Once Empty > Disconnect Session" and minimizing the window to the system tray while the main window is maximized.
Settings:
  • Preferences > Environment > Uncheck (Disable) "Closing sessions when exiting application" and "Exiting application on operation completion"
  • Preferences > Environment > Window > Check (Enable) "Minimize main window to taskbar status area (system tray)"
I'd expect main window to open up maximized again on next session since the window was maximized the last time before it was minimized to the system tray.
  1. Enable / Disable the options above as listed
  2. Start a large enough background transfer that takes a min or 2
  3. Enable "Once Empty > Disconnect Session"
  4. WinSCP main window should be maximized
  5. Minimize the WinSCP main window
  6. Wait for transfer to complete and for WinSCP to close as expected.
  7. Rerun WinSCP and notice the main window is no longer maximized.
Reply with quote E-mail
I've now followed the instructions from your original post again.
I can still reproduce the problem with WinSCP 6.3.7. But it works for me with WinSCP 6.5.1.
Do you happen to have multiple displays maybe? Does it possibly happen on one of them only? Do you have scaling enabled in Windows?
war59312
U.S.A
Yes 2 monitors. No scaling on either. Both 1440p.
Happening on both monitors.
In fact, it's not remember maximized state at all.
That is I can just maximize the session. Disconnect and close winscp with window maximized and then when I reopen a new session window is not maximized anymore.
Feedback from @war59312:
I just decided to check to see how WinSCP is launched.
START /MIN /WAIT /D" C:\Apps\WinSCPPortable\App\WinSCP\" WinSCP.exe /ini="C:\Apps\WinSCPPortable\Data\settings\winscp.ini" /log="C:\Apps\WinSCPPortable\Data\settings\winscp.log"
User error. It's the /MIN that is causing this to fail. Wow, no idea why never caused it before, but all good, /MIN doesn't work anyways, that is, it is not started minimized.
So yeah, good to move on, my fault. Working as expected.
