Download Zip files with WinSCP
prasadgov
Currently, I am able to download files from an FTP server using WinSCP.
These are the daily files which are created every hour.
The previous day's run is zipped and in a folder called Archive with a name 07082024.
If I need to download the zipped files from the Archive, how would I do that?
TIA
Re: Download Zip files with WinSCP
So you know how to download a file. Downloading from another folder should not be different. What exact problem do you have?
prasadgov
What is the command I need to pass to download the zip files?
For individual or the entire files, I use *.txt.
But if these files are zipped and in Archive folder, what is the filetype and how do I retrieve?
