Command line option -remove does not seem to do what I expect
JackElliott
Bend, Oregon, USA
My goal is to remove files from the remote directory that no longer exist in the source directory, but it does not seem to work. The remote folder has a bunch of files that do not exist on the source, and some have been there for quite a while. How can I make this work? Example working (except for -remove) command:
synchronize remote -delete -resumesupport=on -filemask=*.mp3|*/
Thank you!
Re: Command line option -remove does not seem to do what I expect
So did you use -delete or -remove?
Anyway, please post a session log file (/log) and give us a name of the file that should have been deleted but was not.
JackElliott
Bend, Oregon, USA
Thank you. The command I'm using is
But it might make better sense for me to say what I'm looking for!
I want to transfer files from Local to Remote, overwriting any existing files already on Remote, and deleting any files not found on Local. Basically mirror Local to Remote.
I thought the synchronize command would to that, but I reckon I am misreading what synchronize does.
