Same command with issues locally
asnon
Local is Windows
Remote is Linux
local custom command:
sha256sum --tag * > hash.txt
Two problems: this will not run in the current dir in the local pane, rather the WinSCP installation dir, and it will not pipe the output into a new file called hash.txt.
You can sort of fix the first issue with
sha256sum --tag "!\"\* > hash.txt
However no idea about the second issue.
Re: Same command with issues locally
Output redirections is feature of cmd shell.
You can do the following to some both your problems:
cmd /c cd !\ & sha256sum --tag * > hash.txt
