Can't Upload File with Parenthesis in Name
aksarben
I just downloaded version 6.3.5, Build 14991, 2024-09-10, discovered it no longer accepts files with parentheses in the file name. This affects thousands of files on our Web site.
Was this a intentional change? If so, why? Parentheses are perfectly legitimate characters in Windows file names.
If it was not intentional, how long before this bug can be fixed?
Re: Can't Upload File with Parenthesis in Name
I'm not aware of such change. What exactly does it mean "[not] accepts files"? Please attach a full session log file showing the problem (using the latest version of WinSCP).
