Version 3.6.5 unstable?
I have just updated to version 3.6.5. It opens fine, makes the connections to my Linux virtual computers, but if you leave it logged in, it later will not restore the window and needs to be stopped via the Task Manager. No error message reported, just not stable.
Did not have that problem with earlier versions.
Version 3.6.5 (Upgraded over 3.6.4)
tested on Windows 10 and 11 (Pro), 3 computers, each same problem
SFTP connection or multiple connections
No log file created or error message, program just hangs.
