Open directory/bookmark should also be able to handle files
Sopor
Sopor avatar
Sweden
It is possible to bookmark a directory, but not a file.
To bookmark a file maybe sounds silly, but it is quite nice if that was possible.
As it works now it will only go to the top of that directory I have bookmarked and I have to manually scroll down to the file, but if a file is also added to the end of the bookmark it will also jump to the file.
So, if i add /etc/rc.local as a bookmark it will change directory, scroll and place the cursor on the file rc.local.
