Issue with criteria=time,size
geek569
WinSCP reports
Nothing to synchronize
with these args:
synchronize remote -criteria=time,size -transfer=binary -mirror -delete
and these files:
local lib.dll with size=433,560 bytes and timestamp1
remote lib.dll with size=433,048 bytes and same timestamp1
the remote file is stored on SFTPGo server
Re: Issue with criteria=time,size
