WinSCP returned with File does not exist
billierios
I have been running WinSCP in scripting mode from a Windows batch file on a Windows 2003 server. I got into a situation where the put operation complained about not finding the file to transfer, but I still did not get any Windows level error code back.
Re: WinSCP returned with File does not exist
