WinSCP scripting - Turn Off Optimize Connection Buffer
jval01
Los Angeles
Hi there,
I am fairly new to WinSCP scripting but if I wanted to turn off the Optimize connection buffer size:
2024-11-20 07:00:18.061 Note: If the problem repeats, try turning off 'Optimize connection buffer size' what is the syntax I would use? Task scheduler is running a .BAT file which then uploads the file to the site.
Thank you!
Reply with quote E-mail
