ssh-copy-id script
henry3
ssh-copy-id script
When I use Tools > Install Public Key into Server command, I notice it checks to see if the key already exists. Do you download authorized_keys and check it locally, or call grep on the remote server? I wanted to add a new key to a list of servers, and did it using put -append, but that doesn't check if the key is already on that server. I didn't see a way to get the result code from a call, other than creating some type of flag.
Henry
Re: ssh-copy-id script
The "Install Public Key into Server" uses pure SFTP, so it cannot do any "grep". It downloads and checks locally. I'll consider adding a command-line equivalent.
henry3
Thanks Martin
if I run
winscp.exe /log=log.txt /copyid user@host.com
I get:
Identity/key file was not specified.
and no logfile created
If I run it with
winscp.exe /copyid -i .ssh\id.pub user@host.com
it works. Is there a default .pub location?
Henry
