File listing possible under Windows 10/11 but not under Windows 7/2008 R2
guedz
France
I encounter a case with a "Maverick SSHD 1.7.32 (0) by JADAPTIVE Limited" Server software:
With a recent operating system, no problem, but with a Windows 7 or 2008 R2 generation OS, it's impossible to list the contents of a folder.
Windows 2008 R2
. 2024-11-29 10:05:15.183 Using SFTP protocol.
. 2024-11-29 10:05:15.183 Doing startup conversation with host.
< 2024-11-29 10:05:15.183 Script: Starting the session...
> 2024-11-29 10:05:15.183 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2024-11-29 10:05:15.215 Type: SSH_FXP_VERSION, Size: 94, Number: -1
. 2024-11-29 10:05:15.215 SFTP version 4 negotiated.
. 2024-11-29 10:05:15.215 Server requests EOL sequence "\n".
. 2024-11-29 10:05:15.215 Server software: Maverick SSHD 1.7.32 (0) by JADAPTIVE Limited
. 2024-11-29 10:05:15.215 We will use UTF-8 strings as it is mandatory with SFTP version 4 and newer
> 2024-11-29 10:05:15.215 Type: SSH_FXP_EXTENDED, Size: 63, Number: 200
. 2024-11-29 10:05:15.215 Changing directory to "/FOLDER".
. 2024-11-29 10:05:15.215 Getting real path for '/FOLDER'
> 2024-11-29 10:05:15.215 Type: SSH_FXP_REALPATH, Size: 16, Number: 272
< 2024-11-29 10:05:15.246 Type: SSH_FXP_STATUS, Size: 64, Number: 200
. 2024-11-29 10:05:15.246 Discarding reserved response
< 2024-11-29 10:05:15.277 Type: SSH_FXP_NAME, Size: 67, Number: 272
. 2024-11-29 10:05:15.277 Real path is '/FOLDER'
. 2024-11-29 10:05:15.277 Trying to open directory "/FOLDER".
> 2024-11-29 10:05:15.277 Type: SSH_FXP_LSTAT, Size: 20, Number: 519
< 2024-11-29 10:05:15.436 Type: SSH_FXP_ATTRS, Size: 52, Number: 519
. 2024-11-29 10:05:15.436 Getting current directory name.
. 2024-11-29 10:05:15.436 Startup conversation with host finished.
< 2024-11-29 10:05:15.436 Script: Session started.
< 2024-11-29 10:05:15.436 Script: Active session: [1] test
> 2024-11-29 10:05:15.436 Script: ls /FOLDER/
. 2024-11-29 10:05:15.436 Listing directory "/FOLDER".
> 2024-11-29 10:05:15.436 Type: SSH_FXP_OPENDIR, Size: 16, Number: 779
< 2024-11-29 10:05:15.468 Type: SSH_FXP_HANDLE, Size: 10, Number: 779
> 2024-11-29 10:05:15.468 Type: SSH_FXP_READDIR, Size: 10, Number: 1036
< 2024-11-29 10:05:15.501 Type: SSH_FXP_STATUS, Size: 51, Number: 1036
< 2024-11-29 10:05:15.501 Status code: 1
. 2024-11-29 10:05:15.501 Listing file "/FOLDER/..".
> 2024-11-29 10:05:15.501 Type: SSH_FXP_LSTAT, Size: 23, Number: 1287
< 2024-11-29 10:05:15.642 Type: SSH_FXP_ATTRS, Size: 52, Number: 1287
. 2024-11-29 10:05:15.642 ..;D;0;2024-11-29T09:05:15.000Z;4;"300" [0];"100" [0];rwx------;0
> 2024-11-29 10:05:15.642 Type: SSH_FXP_CLOSE, Size: 10, Number: 1540
< 2024-11-29 10:05:15.642 Script: Drwx------   0 300      100           1024 Nov 29 10:05:15 2024 ..
> 2024-11-29 10:05:15.642 Script: close
. 2024-11-29 10:05:15.642 Closing connection.
. 2024-11-29 10:05:15.642 Sending special code: 1
. 2024-11-29 10:05:16.033 Session sent command exit status 0
. 2024-11-29 10:05:16.033 Main session channel closed
. 2024-11-29 10:05:16.033 All channels closed
With Windows 11
. 2024-11-29 10:08:44.878 Using SFTP protocol.
. 2024-11-29 10:08:44.879 Doing startup conversation with host.
< 2024-11-29 10:08:44.879 Script: Starting the session...
> 2024-11-29 10:08:44.880 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2024-11-29 10:08:44.915 Type: SSH_FXP_VERSION, Size: 94, Number: -1
. 2024-11-29 10:08:44.915 SFTP version 4 negotiated.
. 2024-11-29 10:08:44.915 Server requests EOL sequence "\n".
. 2024-11-29 10:08:44.915 Server software: Maverick SSHD 1.7.32 (0) by JADAPTIVE Limited
. 2024-11-29 10:08:44.915 We will use UTF-8 strings as it is mandatory with SFTP version 4 and newer
> 2024-11-29 10:08:44.915 Type: SSH_FXP_EXTENDED, Size: 63, Number: 200
. 2024-11-29 10:08:44.915 Changing directory to "/FOLDER".
. 2024-11-29 10:08:44.915 Getting real path for '/FOLDER'
> 2024-11-29 10:08:44.915 Type: SSH_FXP_REALPATH, Size: 16, Number: 272
< 2024-11-29 10:08:44.951 Type: SSH_FXP_STATUS, Size: 64, Number: 200
. 2024-11-29 10:08:44.951 Discarding reserved response
< 2024-11-29 10:08:44.954 Type: SSH_FXP_NAME, Size: 67, Number: 272
. 2024-11-29 10:08:44.954 Real path is '/FOLDER'
. 2024-11-29 10:08:44.954 Trying to open directory "/FOLDER".
> 2024-11-29 10:08:44.955 Type: SSH_FXP_LSTAT, Size: 20, Number: 519
< 2024-11-29 10:08:44.998 Type: SSH_FXP_ATTRS, Size: 52, Number: 519
. 2024-11-29 10:08:44.998 Getting current directory name.
. 2024-11-29 10:08:44.998 Startup conversation with host finished.
< 2024-11-29 10:08:44.999 Script: Session started.
< 2024-11-29 10:08:44.999 Script: Active session: [1] test
> 2024-11-29 10:08:44.999 Script: ls /FOLDER/
. 2024-11-29 10:08:44.999 Listing directory "/FOLDER".
> 2024-11-29 10:08:44.999 Type: SSH_FXP_OPENDIR, Size: 16, Number: 779
< 2024-11-29 10:08:45.038 Type: SSH_FXP_HANDLE, Size: 10, Number: 779
> 2024-11-29 10:08:45.038 Type: SSH_FXP_READDIR, Size: 10, Number: 1036
< 2024-11-29 10:08:45.077 Type: SSH_FXP_NAME, Size: 1007, Number: 1036
> 2024-11-29 10:08:45.077 Type: SSH_FXP_READDIR, Size: 10, Number: 1292
< 2024-11-29 10:08:45.113 Type: SSH_FXP_STATUS, Size: 51, Number: 1292
< 2024-11-29 10:08:45.113 Status code: 1
> 2024-11-29 10:08:45.113 Type: SSH_FXP_CLOSE, Size: 10, Number: 1540
. 2024-11-29 10:08:45.113 REPORT_1122180505026;-;885;2024-11-25T11:00:55.000Z;4;"200" [0];"100" [0];rw-------;0
. 2024-11-29 10:08:45.113 REPORT_1122140940887.txt;-;4184;2024-11-25T11:11:58.000Z;4;"200" [0];"100" [0];rw-------;0
. 2024-11-29 10:08:45.113 REPORT_1125142234357;-;433;2024-11-25T13:22:34.000Z;4;"200" [0];"100" [0];rw-------;0
. 2024-11-29 10:08:45.113 REPORT_1125181619062;-;455;2024-11-25T17:16:19.000Z;4;"200" [0];"100" [0];rw-------;0
. 2024-11-29 10:08:45.113 REPORT_1126040723661;-;873;2024-11-26T03:07:24.000Z;4;"200" [0];"100" [0];rw-------;0
. 2024-11-29 10:08:45.113 REPORT_1126070334520;-;664;2024-11-26T06:03:34.000Z;4;"200" [0];"100" [0];rw-------;0
. 2024-11-29 10:08:45.113 REPORT_1126141038675;-;1497;2024-11-26T13:10:39.000Z;4;"200" [0];"100" [0];rw-------;0
. 2024-11-29 10:08:45.113 REPORT_1126180721041;-;466;2024-11-26T17:07:21.000Z;4;"200" [0];"100" [0];rw-------;0
. 2024-11-29 10:08:45.113 REPORT_1127140738280;-;433;2024-11-27T13:07:38.000Z;4;"200" [0];"100" [0];rw-------;0
. 2024-11-29 10:08:45.113 REPORT_1127180513383;-;433;2024-11-27T17:05:13.000Z;4;"200" [0];"100" [0];rw-------;0
. 2024-11-29 10:08:45.113 REPORT_1128040540801;-;1082;2024-11-28T03:05:41.000Z;4;"200" [0];"100" [0];rw-------;0
. 2024-11-29 10:08:45.113 REPORT_1128070309178;-;664;2024-11-28T06:03:09.000Z;4;"200" [0];"100" [0];rw-------;0
. 2024-11-29 10:08:45.113 REPORT_1128140844279;-;1717;2024-11-28T13:08:44.000Z;4;"200" [0];"100" [0];rw-------;0
. 2024-11-29 10:08:45.113 REPORT_1128180630066;-;466;2024-11-28T17:06:30.000Z;4;"200" [0];"100" [0];rw-------;0
. 2024-11-29 10:08:45.113 ..;D;0;1899-12-30T01:00:00.000Z;0;"" [0];"" [0];---------;0
< 2024-11-29 10:08:45.113 Script: -rw-------   0 200      100            885 Nov 25 12:00:55 2024 REPORT_1122180505026
< 2024-11-29 10:08:45.114 Script: -rw-------   0 200      100           4184 Nov 25 12:11:58 2024 REPORT_1122140940887.txt
< 2024-11-29 10:08:45.114 Script: -rw-------   0 200      100            433 Nov 25 14:22:34 2024 REPORT_1125142234357
< 2024-11-29 10:08:45.115 Script: -rw-------   0 200      100            455 Nov 25 18:16:19 2024 REPORT_1125181619062
< 2024-11-29 10:08:45.115 Script: -rw-------   0 200      100            873 Nov 26  4:07:24 2024 REPORT_1126040723661
< 2024-11-29 10:08:45.115 Script: -rw-------   0 200      100            664 Nov 26  7:03:34 2024 REPORT_1126070334520
< 2024-11-29 10:08:45.115 Script: -rw-------   0 200      100           1497 Nov 26 14:10:39 2024 REPORT_1126141038675
< 2024-11-29 10:08:45.115 Script: -rw-------   0 200      100            466 Nov 26 18:07:21 2024 REPORT_1126180721041
< 2024-11-29 10:08:45.116 Script: -rw-------   0 200      100            433 Nov 27 14:07:38 2024 REPORT_1127140738280
< 2024-11-29 10:08:45.116 Script: -rw-------   0 200      100            433 Nov 27 18:05:13 2024 REPORT_1127180513383
< 2024-11-29 10:08:45.116 Script: -rw-------   0 200      100           1082 Nov 28  4:05:41 2024 REPORT_1128040540801
< 2024-11-29 10:08:45.116 Script: -rw-------   0 200      100            664 Nov 28  7:03:09 2024 REPORT_1128070309178
< 2024-11-29 10:08:45.116 Script: -rw-------   0 200      100           1717 Nov 28 14:08:44 2024 REPORT_1128140844279
< 2024-11-29 10:08:45.116 Script: -rw-------   0 200      100            466 Nov 28 18:06:30 2024 REPORT_1128180630066
< 2024-11-29 10:08:45.116 Script: D---------   0                           0              ..
> 2024-11-29 10:08:45.116 Script: close
. 2024-11-29 10:08:45.116 Closing connection.
. 2024-11-29 10:08:45.116 Sending special code: 1
. 2024-11-29 10:08:45.244 Session sent command exit status 0
. 2024-11-29 10:08:45.244 Main session channel closed
. 2024-11-29 10:08:45.244 All channels closed
I think the problem is with the operating system because I have the same problem with other SFTP clients but I don't understand why.
Could you give me an idea?
Best regards
Re: File listing possible under Windows 10/11 but not under Windows 7/2008 R2
Please ask "Maverick SSHD" support about this. We cannot help you here with server-side problems.
guedz
I'm sorry, I'm not sure what you mean because with WinSCP on a recent bone there's no problem, but WinSCP on a Windows 7/2008 R2 bone doesn't work.
Do you really think the problem is server-side when the SFTP client is the same on the OS mentioned?
Sorry, I've misunderstood your original post.
Then most likely your connection details differ on those machines. Please post complete logs from both.
