Running custom commands always leads to error code 2
DK
So the gist of what I'm trying to do is playing a video with ssh and vlc, to put it simply I need to run:
ssh user@target -p PORT cat FILE | vlc -
all the parameters can be provided by WinSCP using the patterns, I also use the "Local command" and "Use remote files" so that it doesn't download and then run the command.
But after running it, I got error code 2 instead, even though the same exact command works on normal cmd terminal, which confuses me. This is the command I tried to run
ssh !U@!@ -p !# cat !/! | vlc -
the error message or the actual log for that matter only says the same thing which doesn't help at all. Here's what it says
System Error. Code: 2.
The system cannot find the file specified
DK
Re: Running custom commands always leads to error code 2
Now some of the time it says it can't find "ssh" for some reason, but the funny thing is, it still can't find it even after I put the absolute path to it
"C:\Windows\System32\OpenSSH\ssh.exe" !U@!@ -p !# cat !/! | vlc -
DK
So I found a solution, it sounds dumb I guess, but I just simply copy the ssh.exe to another folder and it seems to have fixed it somehow, oh well, as long as it works I guess.
