Can't get sftp server to accept password from script when entered as part of the "open" command
JackElliott
Bend, Oregon, USA
I'm setting up a script to send files from a Windows 10 computer to a MacOS (Sequoia 15.2) computer and am unable to get the server on the Mac to accept the user password when it is sent as part of the sftp open command.
It works if I leave out the password, here:
open sftp://username@ip-address/ -hostkey="sha - xxx"
The opened terminal window prompts for the username password, like this:
Searching for host...
Connecting to host...
Authenticating...
Using username "username".
Password:
And when the password for username is entered, the script carries on and does its business.
But if I try to automate the process so I don't have to hand-enter the password, like this:
open sftp://username:password@ip-address -hostkey="sha - xxx"
I get this error:
Authenticating...
Access denied.
Authentication failed.
Access denied.
According to the example on https://winscp.net/eng/docs/scripting#example, the password is put after the username, separated by a colon. So I think I am doing this correctly. But it don't work.
How can I automate this with the password inline with the rest of the open command?
Thank you!
Re: Can't get sftp server to accept password from script when entered as part of the "open" command
Thank you. My password is Oddbirds24
I do not see special characters.
JackElliott
Oh dear, I found a typo in my password. My apologies! It's what my wife calls "male pattern blindness" – ouch
