Remove modular windows
Renko
Modular windows are usually unnecessary. Especially if they also prevent the tab from switching to another connection
Re: Remove modular windows
I assume you mean "modal".
Ok, but you present it as if there was a switch that we can just toggle. It's a huge task to do.
Particularly the part about "prevent the tab from switching", while a window is opened.
