WinSCP script
Barosak
WinSCP script
i am using a script below to upload file to SFTP using proxy, but I am getting Time Out error. How can i fix this? Am I connecting first to proxy and doing everything correctly?
Thank you so much.
# Load Assembly .NET WinSCP (DLL in windows\system32)
Add-Type -Path "C:\Program Files (x86)\WinSCP\WinSCPnet.dll"
# Set session options
# Protocol, user, password, target server, connection info
Protocol = [WinSCP.Protocol]::Sftp # Declare SFTP protocol
HostName = "hostname"
PortNumber = 22
UserName = "username"
Password = "pass"
GiveUpSecurityAndAcceptAnySshHostKey = $true
Timeout = 300000 # Set timeout to 5 minutes (300000 ms)
# Activate WinSCP SFTP session
$session = New-Object WinSCP.Session # WINSCP
# Configure proxy
$session.AddRawConfiguration("ProxyMethod", "3") # 3 = HTTP Proxy
$session.AddRawConfiguration("ProxyHost", "Srv01prox")
$session.AddRawConfiguration("ProxyPort", "80")
$session.AddRawConfiguration("ProxyLoginTimeout", "300000")
# GO
try {
# Open Connection
# File Transfer – default over-write
$transferResult = $session.PutFiles("Time_Actual_IKOS.csv", "/TCZW_IKOS_Plant_Cockpit/")
# Log result
$logMessage = "Upload result: $($transferResult.Transfers.Count) file(s) transferred.`n"
foreach ($transfer in $transferResult.Transfers) {
$logMessage += "Transferred: $($transfer.FileName)`n"
$logMessage | Tee-Object -FilePath "upload_log.txt" -Append
catch {
"Error: $_" | Tee-Object -FilePath "upload_log.txt" -Append
Write-Host "Error: $_"
finally {
$session.Dispose()
Read-Host "Press Enter to exit..."
