Directory Listing -> Dead End
rem
Hello!
I am (also) using shared hosting, where the problem exists, that the full directories are listed at the top of WinSCP like
<root>
/home/
/username/
/www/
/domain.com/
As soon as I use "home", I am not permitted to see anything. However, the problem is, that I cannot select /www/ anymore, because WinSCP does not feature these directories anymore. Same for using the "Top" Arrow.
So WinSCP could be tremendously improved, if it shows just a "forbidden" message, without then also deleting the whole folder structure. So WinSCP would prevent me from beeing trapped, also if I accidentally doubleclick the arrow. Btw. the most annoying feature is, that WinSCP even remembers THAT location at the next login, so the only solution is, that I delete the account info and fully edit the whole login credentials once again...
There must be a better solution. Well, maybe there is one and I must RTFM. But currently, it's a real pain at that single hosting provider with his "traps".
Regards
Reto
