PutFiles uploading files to parent folder after upgrading to v6.3.6 (OpenVMS)
harkapobi
UK
After upgrading from WinSCP version 5.17.10 to 6.3.6 (.Net) the PutFiles method is now uploading files to the folder above the home folder.
This is the code (which hasn't changed)
var sessionOptions = new SessionOptions
    Protocol = Protocol.Ftp,
    HostName = url,
    UserName = username,
    Password = password,
    PortNumber = 21
if (!string.IsNullOrEmpty(proxyPort))
    sessionOptions.AddRawSettings("ProxyHost", proxy);
    sessionOptions.AddRawSettings("ProxyPort", proxyPort);
using (var session = new Session())
    session.Open(sessionOptions);
    var transferOptions = new TransferOptions();
    transferOptions.TransferMode = TransferMode.Ascii;
    var transferResult = session.PutFiles(filePath, "/", options: transferOptions);
    transferResult.Check();
Looking at the logs, the newer version calls CDUP just before uploading the file. I have no idea why. Logs for each version are attached (with usernames, server names etc. replaced)
Is there a way I can get it working using the later version?
