WinSCP 6.5 creates suspicious files in Windows-Folder
forumuser
I was surprised when my endpoint protection alerted me about a trojan file named is-IRMP3.exe in C:\Windows.
When I checked the folder, I see this 3 files:
is-IRMP3.exe
is-IRMP3.lst
is-IRMP3.msg
They have the same date as the day WinSCP 6.5 was installed on the machine.
The content of the is-IRMP3.lst and exe files are attached.
What exactly happened here?
Re: WinSCP 6.5 creates suspicious files in Windows-Folder
The installer needed to upgrade DragExt64.dll shell extension. As the extension was already loaded (and thus locked), it could not be replaced at the time of the installation. As the replacement was not critical, the installer delayed the replacement until the next Windows restart (instead of forcing you to restart immediately). Those files are support files for the replacement and registration. The .lst file actually even says that. They should get removed the next time you restart your computer.
