Access to directories
Saul1
I just installed the FileZilla client. It seems to be the same problem. The other target computer is running Windows 11. I have another target computer with the same setup running Windows 10, and access works fine on that one.
Wolfgang
Reply with quote E-mail
So then it's likely indeed permissions problem. Or something changed about security architecture in Windows 11. Btw, I can access Program Files folder using my account (with admin privileges) on Windows 11 server running Win32-OpenSSH.
It does not seem to be a WinSCP question in any case. Please consider asking at a more appropriate place, like Super User. Please, post a link here, if you do.
